TwinTurbo.NET: Nissan 300ZX forum - I'm planning on bypassing the radiator cooler completely
Subject I'm planning on bypassing the radiator cooler completely
Posted by ZXRider on September 10, 2014 at 5:32 PM
  This message has been viewed 213 times.
In Reply To Re: Thank you for your help. You've helped a lot posted by ttz'in (NorCal) on September 09, 2014 at 11:12 PM
Message I am having a very annoying overheating problem that I have not been able to find the problem behind it. I mean I have changed everything, I even purchased a brand new fan clutch. My head gaskets are fine, everything is working in order. Nonetheless, I am trying to bypass the radiator as a transmission cooler to verify that the hot ATF is not heat soaking the radiator. On top of that, if I get this set up correctly, I can purchase a new oversize radiator and help with the hot summer days. Thanks.
