TwinTurbo.NET: Nissan 300ZX forum - White Smoke
Subject White Smoke
Posted by n.romero on September 10, 2014 at 3:18 PM
  This message has been viewed 167 times.
Message Hi all,
New to the forums. I have been searching the forums and haven't quite been able to figure out my issue. I just finished with a plenum pull. Now i have really bad loss of power and also white exhaust smoke under acceleration. Additionally i have intermittent back firing. I did not have any of these issues prior to plenum pull. When the plenum was off i did valve cover reseal, erg bypass, pcv delete, coolant line bypass, new connectors on both coil packs and injectors. I replaced the spark plugs less than 1k ago. Im running out of ideas. Does anyone have suggestions of things to check?
Thanks in advance
