TwinTurbo.NET: Nissan 300ZX forum - Re: Thank you for your help. You've helped a lot
Subject Re: Thank you for your help. You've helped a lot
Posted by ttz'in (NorCal) on September 09, 2014 at 11:12 PM
  This message has been viewed 200 times.
In Reply To Thank you for your help. You've helped a lot posted by ZXRider on September 09, 2014 at 04:24 PM
Message Your welcome.
When i did it the AT cooler lines were on the driver side of radiator and using the radiator cooler as well it was easier to keep lines on that side. (out line of radiator cooler, into TT cooler, out of TT cooler to metal return line to trans.)
If your not going to use, or have a radiator cooler, routing lines through same side as oil cooler should work.
IIRC the AT metal cooler lines do run on passenger side and across front cross member into radiator cooler.
