TwinTurbo.NET: Nissan 300ZX forum - Need help "jumping" fuel pump in order to drain tank
Subject Need help "jumping" fuel pump in order to drain tank
Posted by John PGT on September 07, 2014 at 11:54 PM
  This message has been viewed 704 times.
Message So I'm in the process of de-mothballing a '90TT, and the tank is about half full of older gas which I would like to flush out. My plan is to simply run a hose from the line going into the fuel filter, and catch it in 5 gallon gas containers. I've searched high and low and can't seem to find instructions how to "jump" the fuel pump so it will continually run and drain the tank. It appears the relay is the bright green connector behind the drivers side footwell, but I am unsure exactly which pins to jump in order to run the pump. Any insight will be greatly appreciated. Thanks in advance!
