TwinTurbo.NET: Nissan 300ZX forum - Replace the starter - not expensive and easy to do.
Subject Replace the starter - not expensive and easy to do.
Posted by jzack on September 06, 2014 at 11:38 PM
  This message has been viewed 168 times.
In Reply To No crank issue but intermittent...what would you do? posted by Evan_Wright (Ca) on September 06, 2014 at 11:48 AM
Message Some other things to check - battery ground/battery negative terminal. Clutch pedal switch assuming you have a manual tranny?
FYI - That relay can be jumpered/bypassed as a way to test it if the issue comes up again. Unplug the relay and use a wire to connect the two wire harness (relay) terminals that provide the connection when the relay is energized.
