TwinTurbo.NET: Nissan 300ZX forum - trunk ballast/hicas solenoid removal/etc
Subject trunk ballast/hicas solenoid removal/etc
Posted by wickdGSXR on September 05, 2014 at 3:19 PM
  This message has been viewed 271 times.
Message Hi
1. Where is the trunk ballast? I've removed the panel back panel where the reverse lights are and see nothing.
2. Can I remove the hicas lines all the way back to the rear differential (area) using the Z1 bypass fitting? I will hacksaw crap if I have to because I'm not removing the subframe again. Any electronic stuff to worry about since I am disconnecting connectors at solenoid?
3. Any other stuff to do while engine is out and I'm waiting for the machine shop? I can't delete the CA smog crap. Weight savings, cleaning up engine bay be removing...?
