TwinTurbo.NET: Nissan 300ZX forum - Sadly I already sold my original OEM oil cooler
ZXRider
on September 04, 2014 at 7:28 PM
Re: External Automatic Transmission Cooler for a TT
posted by ttz'in (NorCal)
on September 04, 2014 at 03:51 PM
when I installed a Stillen oil cooler. I am concerned with airflow if I put another heat exchanger right in front of the radiator. That will be the oil cooler, transmission cooler, AC condenser then the radiator. Did you have a set up you mentioned?
ZXRider
16:41:11 09/03/14
5sp conversion (n/m)
BarryGZX
19:43:36 09/03/14
Not an option at the moment. (n/m)
ZXRider
00:05:26 09/04/14
I have two up front behind the Engine oil cooler.
nzryan
20:58:07 09/03/14
You mind posting a picture of your set up?
ZXRider
00:06:00 09/04/14
ttz'in (NorCal)
15:51:04 09/04/14
Sadly I already sold my original OEM oil cooler -
ZXRider
19:28:47 09/04/14
Re: Sadly I already sold my original OEM oil cooler
ttz'in (NorCal)
03:09:37 09/05/14
Yes the Stillen cooler sits where the OEM
ZXRider
17:14:30 09/05/14
Re: Yes the Stillen cooler sits where the OEM
ttz'in (NorCal)
11:50:10 09/07/14
When I said I didn't want to deal with flushing it
ZXRider
15:25:29 09/08/14
Re: When I said I didn't want to deal with flushing it
ttz'in (NorCal)
12:57:21 09/09/14
Thank you for your help. You've helped a lot
ZXRider
16:24:01 09/09/14
Sorry about the delay, here's a couple pics
Sportzcoop
20:23:07 09/09/14
Thank you for the pictures
ZXRider
10:51:43 09/12/14
Re: Thank you for your help. You've helped a lot
ttz'in (NorCal)
23:12:02 09/09/14
I'm planning on bypassing the radiator cooler completely
ZXRider
17:32:09 09/10/14
Re: I'm planning on bypassing the radiator cooler completely
ttz'in (NorCal)
15:38:56 09/11/14
Yes the valve was at the top
ZXRider
16:06:05 09/11/14
Re: Yes the valve was at the top
ttz'in (NorCal)
23:40:11 09/11/14
Since why I want to install an external AT cooler :)
ZXRider
10:50:45 09/12/14
Sportzcoop
22:07:37 09/07/14
