TwinTurbo.NET: Nissan 300ZX forum - Splicing in new connectors for FICD/AAC, Air Reg.
Subject Splicing in new connectors for FICD/AAC, Air Reg.
Posted by Metacom on September 03, 2014 at 1:16 PM
  This message has been viewed 234 times.
Message While attempting to save the connectors on the solenoids of the IAA and Air Regulator I will also need to replace the wire connectors from the EFI harness as they're corroded beyond saving.
I will be following the wrap spliced connection with copper wire then solder and use heat shrink.
Will this spliced connection interfere with the Ohms required for the FICD/AAC and air regulator to operate properly? I see a lot of talk about splicing new injector harnesses on without issue...
