TwinTurbo.NET: Nissan 300ZX forum - Factory states 0.008" is the deck limit
Subject Factory states 0.008" is the deck limit
Posted by -Grimm- on September 03, 2014 at 9:41 AM
  This message has been viewed 152 times.
In Reply To Thanks sir. Can I use OEM HG if heads get shaved? posted by ZUL8R on September 02, 2014 at 09:49 PM
Message for using stock components. That number is combined removal from the block and heads. This is due to the timing shift that happens when the heads get closer to the crankshaft.
Camshaft timing retards approximately (0.15 DS/0.35 PS) degrees per 0.005" removed, assuming heads are decked evenly, which they should be.
You can just as easily deck further if required with oversize head gaskets (i.e. Cometic)
1992 300ZX NA 5 Sp (Dead)
1990 300ZX NA Auto 2+2 (Dead)
1990 300ZX TT 5 Sp (Est. 400 HP)
1990 300ZX TT 5 Sp (Est. 600 HP)
2004 G35 Sport 6MT (DD)
