TwinTurbo.NET: Nissan 300ZX forum - Detonation sounds like Splitting Rocks in the Engine.
Cjw3
on August 31, 2014 at 10:49 AM
what does a boost leak or detonation feel like?
posted by nonstopna
on August 30, 2014 at 11:44 PM
If you have herd all the other normal engine sounds.. Det will jump at at you as a SEVERELY BAD Sound.. and will go away when you back out of it..
Cj
nonstopna
23:44:36 08/30/14
Significant boost leak when flooring would run pig rich
dvice
00:21:58 08/31/14
Its still likely to get detonation at low boost
Summeronthechain (MN)
16:03:34 09/03/14
boost leaks vary
01:24:42 08/31/14
LJ - I have never had a boost leak :) (n/m)
The Devils Z
10:02:53 08/31/14
Detonation sounds like Splitting Rocks in the Engine. -
Cjw3
10:49:04 08/31/14
But I wonder if you are in Knock Retard by the ECU?.. (n/m)
Cjw3
11:38:21 08/31/14
The ECU knock control isn't that fancy
BlackholeZ
13:34:20 08/31/14
It doesn't actually "shut off"
ttsmokin
17:13:45 08/31/14
I like the "marbles in a coffee can"
Zinister1
21:47:33 09/02/14
