TwinTurbo.NET: Nissan 300ZX forum - Correct Rear LCA Ball Joint P/Ns
Subject Correct Rear LCA Ball Joint P/Ns
Posted by ThisIsSparTTa on August 29, 2014 at 12:15 PM
  This message has been viewed 502 times.
Message Having some trouble figuring this out, and getting lots of conflicting information.
Based on a recent thread with a reply from Bernie and another thread with a reply from Bernie, I grabbed some Moog K9820 for my rear lower control arms.
Suspension shop didn't replace them, because he said they are different size. I can't remember which way the numbers went, but he used a caliper and one part was 36mm and the other was 40mm.
I'm working on what used to be an NA. Courtesy Nissan says there is only one P/N for TT/NA rear LCA, but then CZP has a NA OEM LCA and a TT OEM LCA for sale. I can't find anything else saying the arms should be different.
So, what's the deal? Are TT/NA Rear LCA's different? Does that change the ball joint size?
Or is there a different P/N I should be looking for? I've seen a couple of references to a 9633 P/N. Mine are pretty shot, but now have new ES bushings in them, so would rather just replace the ball joint.
