TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Antilock light on and no LED codes continued
Subject Re: Re: Antilock light on and no LED codes continued
Posted by Da Flash on August 28, 2014 at 9:39 PM
  This message has been viewed 280 times.
In Reply To Re: Antilock light on and no LED codes continued posted by ZTom on August 28, 2014 at 08:49 PM
Message I've taken out the interior panel and have seen that the LED isn't flashing.
Per the FSM,
[ http://www.300zx.co.uk/cgi-bin/manual.cgi?list=br&dir=&config=&refresh=&direction=forward&scale=0&cycle=off&slide=52&design=default&total=56 ]
I checked for voltage at the #1 pin of the control units harness with the ignition on and got ~11 volts. Next I checked for voltage between pin #15 and ground and got none. The FSM says to check the alternator harness, which I did and got continuity between the alt harness and the control unit connector.
The colored wiring diagrams have helped a lot but they don't say which fusebox that the FSM/wiring is referring to. The wiring diagram shows that there should be a wire going from the control unit to the alt that branches off to fuse 6K. I'm not sure which fuse/fusebox that is. The FSM does make a reference to a 10A fuse but, the only ABS fuse that I've found is a 20A.
