TwinTurbo.NET: Nissan 300ZX forum - Re: Antilock light on and no LED codes continued
Subject Re: Antilock light on and no LED codes continued
Posted by ZTom on August 28, 2014 at 8:49 PM
  This message has been viewed 272 times.
In Reply To Antilock light on and no LED codes continued posted by Da Flash on August 28, 2014 at 05:09 PM
Message Check the ABS relay. And the ABS modules is locate behind the passenger seat.Take the trim off and you will see it. It have brake lines connect to it. Also disconnect the plug see if the ABS light go off.
