TwinTurbo.NET: Nissan 300ZX forum - But is the CTPS signaling correctly?
Subject But is the CTPS signaling correctly?
Posted by ChristopherTheOne on August 28, 2014 at 1:03 AM
  This message has been viewed 183 times.
In Reply To Re: Agreed. Check TPS. posted by kilr300 on August 26, 2014 at 04:42 PM
Message The TPS unit is actually more than one sensor. It has the rheostat component that will show a range of voltages depending on how wide the throttle is open, and that's what you're seeing on the ECU Talk.
It also has a binary switch that signals ON when the throttle is fully closed, and off when any amount of throttle is applied. This signal is what tells the ECU to go into open-loop mode. If yours isn't signaling when the throttle is closed, then your ECU doesn't know to idle...it keeps running the closed-loop EFI program.
