TwinTurbo.NET: Nissan 300ZX forum - Re: Agreed. Check TPS.
kilr300
on August 26, 2014 at 4:42 PM
Agreed. Check TPS.
posted by ChristopherTheOne
on August 25, 2014 at 11:09 PM
Im getting a reading of .50 on my tps (using ecu talk). That is ok right?
Did my car advance itself?
kilr300
21:05:04 08/24/14
Are you able to adjust with CAS? (n/m)
BarryGZX
08:28:17 08/25/14
Re: Are you able to adjust with CAS?
kilr300
11:32:09 08/25/14
that dont sound right!!
BarryGZX
20:36:47 08/26/14
its actually called the "Cam Indexing Peg"
BarryGZX
20:55:48 08/26/14
I assume this is with the car warmed up?
Woody75 (Denver)
10:32:23 08/25/14
Re: I assume this is with the car warmed up?
kilr300
11:33:48 08/25/14
Idle/rpm is too high.
Woody75 (Denver)
13:15:00 08/25/14
Agreed. Check TPS.
ChristopherTheOne
23:09:20 08/25/14
Re: Agreed. Check TPS. -
kilr300
16:42:12 08/26/14
want it closer to .44 (n/m)
Woody75 (Denver)
11:17:05 08/27/14
Mine was about 0.5V
-Grimm-
11:44:14 08/27/14
But is the CTPS signaling correctly?
ChristopherTheOne
01:03:48 08/28/14
Re: Idle/rpm is too high.
kilr300
16:43:18 08/26/14
Need to start checking things
Woody75 (Denver)
11:18:59 08/27/14
+ Are they synchronized (n/m)
-Grimm-
11:45:04 08/27/14
