TwinTurbo.NET: Nissan 300ZX forum - If springs are still original - should be done as well.
Subject If springs are still original - should be done as well.
Posted by jzack on August 26, 2014 at 9:12 AM
  This message has been viewed 204 times.
In Reply To Re: The times I have seen this it was a bad shock. posted by billc123 on August 26, 2014 at 07:10 AM
Message Going with a mild (approx 1.25 inch) lowering spring is good too. OEM springs will have sagged that much so car will look the same as now. Best to also plan on replacing dust boots - Other parts like bump stops may be fine to reuse, won't know until you pull things apart.
I have the AGX adjustables which work fine but any general repalcement shock for regular driving should be ok. Spring firmness is also a factor...
There are plenty of posts on this both here and on the Internet just do google general search.
