| Subject |
Re: engine bay electrical? |
| Posted by |
Da Flash on August 25, 2014 at 4:39 PM |
This message has been viewed 211 times. |
| In Reply To |
engine bay electrical? posted by angel martinez on August 25, 2014 at 10:43 AM |
| Message |
If all you did was pull the connectors to get the plenum off, then you'll have the 6 coilpacks, 6 injectors, fuel temp, IAA solenoid, FICD solenoid, air reg solenoid, 2 O2 sensors, and 2 VTC's. There are the connectors over by the battery but, I can't recall which ones and it depends if you have deletes or not. Look for a "how to pull the plenum" and it should get you going in the right direction. If you get stumped, post a pic and someone should help you out.
| Follow Ups |
Post a Followup |
