TwinTurbo.NET: Nissan 300ZX forum - If compressor is turning and refrigerant charge
Subject If compressor is turning and refrigerant charge
Posted by JMartz on August 25, 2014 at 1:24 PM
  This message has been viewed 245 times.
In Reply To Compressor and relay work, refrigerant is full. (n/m) posted by gjohnson25 on August 25, 2014 at 07:32 AM
Message is correct, then you need to hook-up a gauge set and look at the high and low pressures. If pressures are ok, the expansion/by-pass valve is stuck on by-pass and the evaporator is no getting any cooling. If pressures are out of specification, then compressor is not compressing.
