TwinTurbo.NET: Nissan 300ZX forum - Braided steel with AN fittings not necessary but nice >>
Subject Braided steel with AN fittings not necessary but nice >>
Posted by ZUL8TR on August 25, 2014 at 5:36 AM
  This message has been viewed 286 times.
In Reply To Re: Who ever does it, pressure test the injectors on the >> posted by BRMZ on August 24, 2014 at 03:13 PM
Message stuff. For the front crossover the metal 90 degree fitting is needed for no kinking in tight quarters. I used the steel braided with AN fittings for front crossover and the rear in and out supplemented with the Goodyear hose where needind additional (see below). What ever you use make sure it is rated for high pressure injector systems and all connections are leak free. Nissan OEM hose is very expensive. I have used the Goodyear fuel injector hose with the blue inside liner, rated 100 psi working 900 psi burst:
[ http://www.goodyearep.com/ProductsDetail.aspx?id=5144 ]
I believe I used 5/16" ID but verify. picked it up at Auto Zone.
ZUL8TR in Orlando,FL
