TwinTurbo.NET: Nissan 300ZX forum - Re: Major Power Loss Issues Ongoing...
Subject Re: Major Power Loss Issues Ongoing...
Posted by Cjw3 on August 22, 2014 at 8:32 PM
  This message has been viewed 138 times.
In Reply To Major Power Loss Issues Ongoing... posted by HellOnWheelZ on August 22, 2014 at 06:00 PM
Message Need to look at Fuel Mixtures.. Widebands are good..
OR
Grab a ECU Talk, and Connector..
Look at your O2 Sensor voltage when it starts 'Falling Off'..
When you are 'In' the throttle, you should always have greater than .8 volt..
If the O2 Sensor Voltage falls below that you have a Mixture Problem..
You can also look at the Ignition Timing.. See what it's doing.. If it's pulling Timing.. LIKELY it's a Knock Retard..
Cj
