TwinTurbo.NET: Nissan 300ZX forum - Never mind, figured how...
Subject Never mind, figured how...
Posted by JMartz on August 21, 2014 at 1:35 PM
  This message has been viewed 117 times.
In Reply To Brake Vacuum Booster Tech posted by JMartz on August 21, 2014 at 12:44 PM
Message With vacuum pulled, depressing the brake pedal a few times should depleat the vacuum if the atmospheric inlet valve is operating.
If the pressure equalization valve bewteen the front and rear diaphragm chambers was always open, there would be noise and engine misbehavior upon pedal push, as an opening all the way to the manifold would be established. In addion to poor assist.
If the pressure equalization valve was closed, the brakes would stay applied.
