TwinTurbo.NET: Nissan 300ZX forum - boost leak from recir valve. fixable??
Subject boost leak from recir valve. fixable??
Posted by LivinTheDream on August 20, 2014 at 5:24 PM
  This message has been viewed 150 times.
Message So the LH or US driver side recir valve is leaking from either the rim where the cap sits on it or a small hole that u can see from the front of the car that's molded in the casting. I feel its coming out of the hole but when i sprayed soapy water on it it didn't bubble. Maybe because its to much air blowing out. Is this fixable or what? Thanks
"torque gets you off the line...& hp gets you over the line." -
TTKeeper
