TwinTurbo.NET: Nissan 300ZX forum - Aftermarket recirc valves
Subject Aftermarket recirc valves
Posted by madkiwi on August 18, 2014 at 5:05 PM
  This message has been viewed 289 times.
Message Hi all,
Turns out my left hand oem recirc valve is leaking to atmosphere. Also turns out that Nissan don't make them any more (while the RH ones can still be had). So while I was searching for a used one I came across the Turboxs H34 and the Bosch CB valves (that Jim Wolf sells).
Has anyone installed either of these as direct replacements for their factory recirc valves, and can you use the stock hoses or do you need to adapt them somehow? Also noticed that neither one has any kind of mounting holes, so I guess you have to fab up a bracket of some kind, unless you want to just have them bouncing around next to the A/C radiator.
Alternatively, does anyone have a used LH recirc valve they removed from a car as part of an upgrade, or a car they are parting out?
Thanks.
