TwinTurbo.NET: Nissan 300ZX forum - no to helicoil
Subject no to helicoil
Posted by aliaZ on August 17, 2014 at 4:27 PM
  This message has been viewed 190 times.
In Reply To Please Advise! Striped threads on the flywheel....FML posted by RRyderTT on August 16, 2014 at 05:43 PM
Message these flywheels already have helicoils. If you pulled the helicoil out, the mating threads in the flywheel are damaged, you'll have to go to something bigger in OD.
A timesert or some other type of solid insert will work, but you are likely out of luck if you think you can use a helicoil.
