TwinTurbo.NET: Nissan 300ZX forum - 1:1 gear ratio
1:1 gear ratio
SammybTT(TN)
on August 17, 2014 at 3:35 PM
What would make a difference if it is in 4th gear? (n/m)
posted by Hatchet502
on August 17, 2014 at 02:26 PM
It the noise still exists it is in your transmission. This is what I learned from a similar issue. Clutch engaged noise is generally a TO bearing. Clutch releasesd (up) is generally input shaft related.
Strange transmission noise
Hatchet502
21:31:40 08/16/14
Couple of questions:
SammybTT(TN)
21:35:56 08/16/14
Re: Couple of questions:
Hatchet502
23:38:47 08/16/14
sounds like TOB if only makes noise when you have clutch
ZXoltan
06:00:20 08/17/14
^ 2nd, I agree with Brandon, sounds like a TO bearing issue (n/m)
SammybTT(TN)
08:24:15 08/17/14
It has a brand new koyo TOB
Hatchet502
09:17:16 08/17/14
I guess you adjusted the clutch pedal travel per the
SammybTT(TN)
13:19:17 08/17/14
Hatchet502
14:26:39 08/17/14
1:1 gear ratio -
SammybTT(TN)
15:35:54 08/17/14
Pilot bushing?
ChristopherTheOne
18:25:37 08/17/14
I replaced that with a Nismo roller at the same time
Hatchet502
19:08:27 08/17/14
its a bearing inside the gearbox itself
kickerzx
08:07:27 08/18/14
Im sure its not a 98+, I got it used from a parts car
Hatchet502
13:32:31 08/18/14
Sorry, I misread. Thanks Chris
ZXoltan
12:40:13 08/18/14
