TwinTurbo.NET: Nissan 300ZX forum - You shouldn't have any blow by after a bottom end rebuild.
Subject You shouldn't have any blow by after a bottom end rebuild.
Posted by ZaXxon on August 17, 2014 at 1:18 PM
  This message has been viewed 158 times.
In Reply To catch can hose restrictor? posted by Barthur on August 17, 2014 at 10:39 AM
Message I plugged all the PCV ports and installed fittings on the intake valve covers and run the hoses open to a catch can. No restrictors, and the hose is 1/2". The only thing that accumulates is skanky water. About 1/2 cup per 1500 miles.
Did you rebuild the bottom end yourself?
You definitely don't want to return to the cold air intakes, as all that oil will go through your turbos and intercoolers.
DSCN1525
