TwinTurbo.NET: Nissan 300ZX forum - Specialty Z Helped with my Hicas/ ABS Light!
Subject Specialty Z Helped with my Hicas/ ABS Light!
Posted by gentlemanof06 on August 14, 2014 at 9:49 PM
  This message has been viewed 303 times.
Message Posting this for two reasons: Giving an awesome review to the guys at Specialty Z and informing anyone with a Hicas/ABS light how to potentially solve it.
First off, I would like to thank John at Specialty Z for helping me with this problem. My hicas/abs lights were on and I did not know why. I called around and then called Specialty Z and told him the problem. Basically if you have this problem, check the fuse panel behind the dead pedal and see if your 15amp fuse is blown for the hicas. It would be the 3rd row down and the only fuse with 15amps on that row. I went to replace it and it blew out again meaning there was a short somewhere. Come to find out it was the wire to my boost guage that was exposed. I fixed that, put in a new fuse and good to go. So, thanks again to John at SZ; you are the man and if any of you have this problem with the HICAS/ABS lights and your automatic window rolldown isn't working, here's the solution. Take care guys!
