TwinTurbo.NET: Nissan 300ZX forum - Overheating, and that is, repeated overheatings or
Subject Overheating, and that is, repeated overheatings or
Posted by JMartz on August 14, 2014 at 7:11 AM
  This message has been viewed 163 times.
In Reply To overheated what now posted by backinblack626 on August 14, 2014 at 06:37 AM
Message a good long drive boiling over, usually causes top end damage. Things like warped head surfaces. Your concern is damage from the resistance the crank and rods felt when one or more pistons could not move in their bores because of the presence of water/glycol.
Unfortunately, after an event like hydrolocking, it may be necessary to look at the bearings and connecting rods. When the heads are off, rotating the motor and observing if the pistons all get up to the same spot relative to the deck, may tell you if a rod is bent.
The iron block of the Z32 should have fared well. I have had a cracked block in the past, in a motor that overheated but that may have been a casting flaw in that particular engine. That was a Ford 390.
