TwinTurbo.NET: Nissan 300ZX forum - I used wood to tap the bolt out
Subject I used wood to tap the bolt out
Posted by -Grimm- on August 13, 2014 at 12:36 PM
  This message has been viewed 111 times.
In Reply To DONT tap on the end of the bolt to loosen posted by ZXoltan on August 13, 2014 at 10:04 AM
Message I wouldn't recommend using a torch.
You'll probably need to heat it up ~150 degrees above room temp to get the bolt to be pushed out (still with some force). If anything I would recommend putting it in your oven to heat evenly and prevent any possible deformation (its easy to create hot spots with a torch)
The aluminum will expand quicker than the bolt.
1992 300ZX NA 5 Sp (Dead)
1990 300ZX NA Auto 2+2 (Dead)
1990 300ZX TT 5 Sp (Building)
2004 G35 Sport 6MT (DD)
