TwinTurbo.NET: Nissan 300ZX forum - Obviously youre burning oil
Subject Obviously youre burning oil
Posted by -Grimm- on August 12, 2014 at 10:07 AM
  This message has been viewed 239 times.
In Reply To My TT is blowing smoke posted by iamdan012 on August 11, 2014 at 08:45 PM
Message Has been posted a few times recently
Causes, in order of what I would personally troubleshoot:
1) PCV valves (Remove oil fill cap, put your palm over it. excessive pressure can mean bad PCV valves and/or bad rings)
2) Valve stem seals (Will only smoke when cold/startup)
3) Piston rings (Dry vs. wet Compression, leakdown test. Leakdown through the oil fill cap means worn rings)
4) Turbo seals (No way to troubleshoot on car, pull the engine)
1992 300ZX NA 5 Sp (Dead)
1990 300ZX NA Auto 2+2 (Dead)
1990 300ZX TT 5 Sp (Building)
2004 G35 Sport 6MT (DD)
