TwinTurbo.NET: Nissan 300ZX forum - I believe you are correct but don't understand why it
Subject I believe you are correct but don't understand why it
Posted by SammybTT(TN) on August 11, 2014 at 7:05 PM
  This message has been viewed 217 times.
In Reply To Timing loop should be on the PTU harness. posted by -Grimm- on August 11, 2014 at 06:47 PM
Message is looped like it is as it appears to be the original condition and I don't want to disturb it if it is a testing loop.
I believe it goes to the center pin of the coil pack connectors and the F23 wire that comes from the IGN relay via the E10 connector.
I want to cut this wire and then trace it out to determine the origination and final destination but thought I would ask the experts on here if they have any experience with this.
Guess I will double check the wiring one more time before I cut and tap into this wire. The main reason for this wire as it is easier to access than trying to locate the same wire underneath the relay blocks.
If push comes to shove and no one can tell me it will be cut (live and learn) lol
