TwinTurbo.NET: Nissan 300ZX forum - High Beams Only
Subject High Beams Only
Posted by phzuidema on August 05, 2014 at 2:02 PM
  This message has been viewed 517 times.
Message Here's a tip for those with the dreaded "high beams only" problem. That is, no parking, fog, side marker lights... high beams only.
This drove me nuts. Replaced the fuse (looked, and it turned out, it WAS( good, with a new one, which got it working for a while. Then same problem again.
SOLUTION was that the fuse box prongs were all a little loose. So, took out the fusebox, adjusted the prongs to tight again (after 24 years, things loosen up). Bonus was I got my cigarette lighter/aux power socket working all over again. Woo hoo! Let there be lights.
