TwinTurbo.NET: Nissan 300ZX forum - Electrical guru question
Subject Electrical guru question
Posted by TriniTT on August 06, 2014 at 11:30 AM
  This message has been viewed 305 times.
Message I'm working on my wiring for my sr swap, and I noticed that the sr20 ecu does not have a provision for the ac/electrical fan. The signal to turn on the fan on the z comes from pin 19 on the z32 ecu directly to the fan relay (for na models). I'm curious if I could splice in the ac relay wire (same as pin 9 on the z32 ecu) to kick on the accessory fan. My understanding is that this will signal the fan to kick on only when the ac is switched on, which is exactly my goal. Any thoughts or suggestions?
Cheers,
JBrobst
