TwinTurbo.NET: Nissan 300ZX forum - better yet....
Subject better yet....
Posted by wickdGSXR on August 09, 2014 at 5:58 PM
  This message has been viewed 179 times.
In Reply To Time for a rebuild, need upgrade advice posted by Mikester(Seattle) on August 08, 2014 at 03:41 PM
Message pay my gas and I'll drive up with cherry picker and give you a hand pulling the motor. I'm twiddling my thumbs waiting for the machine shop to finish so I can start building. Here is a list to ponder....
z1 clutch line 25
fork kit 93
idler studs 30
freeze plugs 5
throwout bearing 29
z1 oil cooler upgrade 220
throttle body gaskets 6
exhaust manifold gasket 40
EGR gaskets 8
oil filter tree gasket+o-ring 6
main seal retainer gasket 2
water pump 75
coolant bypass (metal) 35
heater core hose clamp 20
PCV hose clamps 2.4.4 8
AIV hose clamps 7.1 8
AAC hose kit 44
heater hoses 26
PCV hose kit 84
2 -2.25 hose coupler 32
1.75-2.5 hose coulpler 32
BDE engine mounts 390
water pump pulley+belt 100
Eagle rods 510
ARP main studs 94
Cometic 90mm head gaskets 190
thermostat 18
O2 sensor 198
detonation harness 33
oil pump gasket 2
oil pickup 25
oil pump 166
SZ oil pan 595
coil pack connectors 36
timing belt kit 499
plugs 50
main seal 29
6 puck clutch 600
3" exhaust 1050
exhaust gaskets 3"x4 36
exhaust gaskets 3"x2 20
SZ testpipes 540
JWT 500+ cams 1285
SZ 740cc fuel kit 1425
Ashspec intercooler piping 625
Ashspec planar intake 395
Sellin MAF 280
MAF 150
steering rack bushings 16
Ashspec massives 800
