TwinTurbo.NET: Nissan 300ZX forum - Driver side door lock not working
Subject Driver side door lock not working
Posted by ztunerz on August 06, 2014 at 12:24 AM
  This message has been viewed 243 times.
Message Have an issue with a car where the driver side door lock will not actuate with the key or with latch on the driver side. It will however lock if you use the key on the passenger side door or if you use the latch on the passenger side door. I confirmed that all the actuator arms and cables work as intended.
Looks like it might be an electrical issue in the door lock switch but only affects part of it ? if so whats the solution ? New door lock switch or am I missing something ?
Harry
Formerly yellowzxtt
