TwinTurbo.NET: Nissan 300ZX forum - I assume it works correctly now?
Subject I assume it works correctly now?
Posted by The Sixth on August 04, 2014 at 1:25 PM
  This message has been viewed 183 times.
In Reply To Antenna Switch/Wiring Question posted by RedKev on August 03, 2014 at 09:09 PM
Message If so, don't worry too much about which wire it is on the car side. I've done this in my car, but as Grimm pointed out, the factory wire may not be colored the same.
Just cut the blue wire (#3) and splice some extra wired on each side to run your switch to wherever you need it. Much better to hack into a $15 harness than the factory one.
