TwinTurbo.NET: Nissan 300ZX forum - I'm seeing conflicting information
Subject I'm seeing conflicting information
Posted by -Grimm- on August 04, 2014 at 12:07 PM
  This message has been viewed 177 times.
In Reply To Antenna Switch/Wiring Question posted by RedKev on August 03, 2014 at 09:09 PM
Message Two sites said Black/Red is the antenna control, one said Green/Black.
Also, it appears there are two Black/Red wires. One for a speaker, one for the antenna. The speaker wire should be on a different harness.
According to these diagrams, the blue wire you spliced into is the power supply to the stereo, so that is why it wouldn't turn on with that connected to the antenna.
The stereo will only have the antenna up if it is in radio mode, so if you want to control the antenna manually (like an override) wire the stereo's antenna wire to a toggle switch, wire the other side to the black/red wire on the car side.
1992 300ZX NA 5 Sp (Dead)
1990 300ZX NA Auto 2+2 (Dead)
1990 300ZX TT 5 Sp (Building)
2004 G35 Sport 6MT (DD)
