TwinTurbo.NET: Nissan 300ZX forum - My coolant mixed with engine oil was bad heads.
Subject My coolant mixed with engine oil was bad heads.
Posted by Cjw3 on August 03, 2014 at 1:39 PM
  This message has been viewed 157 times.
In Reply To Cylinder wall rusted / cracked posted by quadratique on August 03, 2014 at 01:22 PM
Message It ended up being a cross drilled hole that feeds both cams with oil.. had cracked through on BOTH HEADS. Do not know if that was before or after the severe heating, as it all went down hill in a big furball mess fast.
My coolant was so bad, that it looked like Peanut Butter. Had to replace everything rubber.. Including the Heater Core because of the rubber Seals on the Water Temp Valve ..
Cap
