TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Swapping plugs seemed to move the problem!
Subject Re: Re: Swapping plugs seemed to move the problem!
Posted by Z32CheekiBreeki on August 01, 2014 at 10:42 PM
  This message has been viewed 162 times.
In Reply To Re: Swapping plugs seemed to move the problem! posted by Ted (92TT) on August 01, 2014 at 08:10 PM
Message Yup replaced them with a set right from Nissan and she's running good now! Thou I broke one of the new ones putting it in :/ luckily one of the cylinders had an ngk in it that looked fairly new so I just put that in place. I didn't gap the plugs, I didn't want to mess with that tiny tip, will I run into any issues?
Also can't get the nut back on the driver side balance tube, think I'm gonna just file the built in washer down a bit since I need only about a half mm of clearance to get past the fuel line that's in the way
