TwinTurbo.NET: Nissan 300ZX forum - Re: Can a Z run "well" on only 5 cylinders?
Subject Re: Can a Z run "well" on only 5 cylinders?
Posted by Z32CheekiBreeki on August 01, 2014 at 12:29 PM
  This message has been viewed 187 times.
In Reply To Can a Z run "well" on only 5 cylinders? posted by Z32CheekiBreeki on July 30, 2014 at 11:52 PM
Message Okay so swapping ign coils didn't seem to move the problem however, when I do the power balance test again paying more close attention, I notice that unplugging the coil on the problematic cylinder does make a difference, engine starts to shake and run rough, just not to the extent of the other cylinders
I think because it is on a cold start it is more noticeable
Is it possible that the plug is getting spark but since it is the wrong plug a misfire is occuring?
