TwinTurbo.NET: Nissan 300ZX forum - Re: thanks for all the answers
Subject Re: thanks for all the answers
Posted by aliaZ on July 30, 2014 at 3:15 PM
  This message has been viewed 380 times.
In Reply To thanks for all the answers posted by Carlos Ramirez on July 30, 2014 at 01:45 PM
Message :So let say it has to much oil. What should I do now?
:1. Do I need get a replacement pressure relief valve? Do I need to have it vacuumed out again, oil replaced? you can take the valve apart with a screwdriver and reseat it, unless it is the newer style with a rupture disc. The only way to remove oil is to flush it. Vacuuming it won't get it done.
:2. I was thinking of replacing my low pressure switch the newer 94 dual pressure switch got a new plug to support the new one.
This is a direct plug and play sensor: [ http://www.action-ac.com/AC-Part/29-30703-3.html ]
Am I right in thinking that this would have stopped from blowing off the pressure valve in the first place? yes
:3. The system should be empty now should I go ahead and gut the STV as mentioned in here? [ http://z32.wikispaces.com/Suction+Throttle+Valve ] yes, but I would splice in a TCA to prevent evaporator freezeup
[ http://www.twinturbo.net/nissan/300zx/forums/technical/view/1143864/yep.html ]
:4. Should I replace the condenser with a newer 94? Will the 94+ work on the 90 without any problems or is there an adapter kit required?
94+ is a direct bolt-in. This will reduce your high side pressures as well
:I guess I need some direction and I kind of frustrated as I saw a wire break on the EFI harness and the main harness already.
:Thanks in advance.
