TwinTurbo.NET: Nissan 300ZX forum - thanks for all the answers
Subject thanks for all the answers
Posted by Carlos Ramirez on July 30, 2014 at 1:45 PM
  This message has been viewed 454 times.
In Reply To NEW AC problem pressure relief valve went off posted by Carlos Ramirez on July 29, 2014 at 10:18 AM
Message So let say it has to much oil. What should I do now?
1. Do I need get a replacement pressure relief valve? Do I need to have it vacuumed out again, oil replaced?
2. I was thinking of replacing my low pressure switch the newer 94 dual pressure switch got a new plug to support the new one. Am I right in thinking that this would have stopped from blowing off the pressure valve in the first place?
3. The system should be empty now should I go ahead and gut the STV as mentioned in here? [ http://z32.wikispaces.com/Suction+Throttle+Valve ]
4. Should I replace the condenser with a newer 94? Will the 94+ work on the 90 without any problems or is there an adapter kit required?
I guess I need some direction and I kind of frustrated as I saw a wire break on the EFI harness and the main harness already.
Thanks in advance.
