TwinTurbo.NET: Nissan 300ZX forum - High pressure can only be caused by a blockage in
JMartz
on July 29, 2014 at 12:42 PM
NEW AC problem pressure relief valve went off
posted by Carlos Ramirez
on July 29, 2014 at 10:18 AM
the system somewhere. Frequently this occurs in the condenser but can occur elsewhere. If you have filled the system with r134a and did not eliminate the TSV, cooling is going to be poor.
Carlos Ramirez
10:18:49 07/29/14
High pressure can only be caused by a blockage in -
JMartz
12:42:00 07/29/14
high pressure can also be caused by inadequate airflow
aliaZ
12:34:28 07/30/14
Re:I can take you step by step
ZTom
12:27:40 07/30/14
I will call you later tonight :-) (n/m)
Carlos Ramirez
13:46:53 07/30/14
Re: NEW AC problem pressure relief valve went off
aliaZ
12:44:00 07/30/14
Re: Re: your condenser fan is not on
ZTom
14:19:38 07/30/14
thanks for all the answers
Carlos Ramirez
13:45:53 07/30/14
Re: thanks for all the answers
aliaZ
15:15:24 07/30/14
I am going to work on this wont be able to update
Carlos Ramirez
02:27:44 07/31/14
My other concern is if the STV valve is not blocked
Carlos Ramirez
10:39:04 07/31/14
Re: My other concern is if the STV valve is not blocked
aliaZ
17:30:51 07/31/14
