TwinTurbo.NET: Nissan 300ZX forum - need more info
Subject need more info
Posted by Carlos Ramirez on July 28, 2014 at 8:26 AM
  This message has been viewed 116 times.
In Reply To 300zx tt Super Afc tuning settings? posted by N_Da_Shadows on July 27, 2014 at 06:23 PM
Message basically on the AFC there is only a few things that have to be set correctly
1. MAF type you have HW-2 btw if factory
2. How many MAFs you have if you have 2 and your ECU is expecting 1 you need to put output to ADD if you have 2 and your ecu is a twin pop ecu then you do AVE (average)
3. You need to set he number of cylinders 6 (duh)
4. TPS is up and to the right arrow.
that should get you started if you lost your setting for your AFC because of power reset you are SOL :-)
