TwinTurbo.NET: Nissan 300ZX forum - I can try that
Subject I can try that
Posted by Carlos Ramirez on July 25, 2014 at 9:08 AM
  This message has been viewed 184 times.
In Reply To other things to check posted by aliaZ on July 24, 2014 at 11:44 PM
Message but shouldnt 46 be already ground if the AC is on that seems to be the input into the AC to activate the circuit and pin 9 being out the output of the ecu to actually trigger the relay that first goes thru the 2-way pressure switch (using 94+ drier).
BTW I checked the pressure switch it is fine I have even bypassed it.
I am really starting to think its the ECU I also have issues with VSS signal, IACV, and now AC not working .. I checked ground points chassis and ecu.
