TwinTurbo.NET: Nissan 300ZX forum - I realized aliasZ was right..
Carlos Ramirez
on July 24, 2014 at 5:35 PM
The Thermo Switch is for certain years
posted by ZXRider
on July 24, 2014 at 04:47 PM
I have STV (suction throttle valve) and now I am at a loss as to what is causing the compressor to not engage.
A/C not working need some assistance.
Carlos Ramirez
13:10:48 07/24/14
you won't see a signal at the relay if you are low on freon
aliaZ
15:56:32 07/24/14
the FSM speaks of a Thermo Control amplifier
Carlos Ramirez
16:24:09 07/24/14
ZXRider
16:47:19 07/24/14
Carlos Ramirez
17:15:05 07/24/14
I realized aliasZ was right.. -
Carlos Ramirez
17:35:17 07/24/14
other things to check
aliaZ
23:44:26 07/24/14
I can try that
Carlos Ramirez
09:08:14 07/25/14
yes, 46 should be grounded already
aliaZ
10:28:43 07/25/14
... pins 46 and 9 both showing ground
Carlos Ramirez
19:19:04 07/25/14
Check your Ambient Temp Sensor...
Russell.DiVittorio
18:33:51 07/24/14
Can you check function of that sensor using the built-in
ZXoltan
20:11:43 07/24/14
if it is bad or missing, it will throw a trouble code (n/m)
aliaZ
23:46:05 07/24/14
in my 97 maxima the clutch wouldn't engage because
inf
01:13:49 07/25/14
