TwinTurbo.NET: Nissan 300ZX forum - Checked. They are synced. I also tried setting both
dvice
on July 27, 2014 at 3:41 PM
Check that your throttle bodies are synced up.
posted by ZaXxon
on July 27, 2014 at 06:22 AM
throttle bodies so that a thin piece of paper can slide in and out between the butterfly valve. Updated TPS back to 0.44 and changed idle back down to 900. Still no difference so I changed all of that back.
Need urgent help with dual pop
dvice
20:18:47 07/26/14
Might be your base idle.
Tanley
21:22:48 07/26/14
It's already set @ 700, 900 with it plugged in (n/m)
dvice
23:52:38 07/26/14
Greg @ SZ advises 900 rpm base idle for modified engines
zebszx
19:03:13 07/27/14
Tried 900 base. No luck. (n/m)
dvice
21:35:09 07/27/14
ZaXxon
06:22:08 07/27/14
Checked. They are synced. I also tried setting both -
dvice
15:41:05 07/27/14
What voltage and CFM is it pulling with only one MAF plugged (n/m)
kickerzx
14:29:40 07/27/14
0.96 to 1 volt with 6 cfm with passenger side unplugged, car
dvice
15:42:59 07/27/14
Yeah but if you have only one maf hooked up as a single
kickerzx
15:48:44 07/27/14
I'm not able to go back to single pop anymore
dvice
15:53:49 07/27/14
Aha.. Well be sure the plates are synced as ZaxXon..
kickerzx
16:13:01 07/27/14
An update:
dvice
21:57:39 07/27/14
Hmmmm. What about a check of some basics.
ZaXxon
04:27:00 07/28/14
