TwinTurbo.NET: Nissan 300ZX forum - Re: The brown connector next to relay box
Subject Re: The brown connector next to relay box
Posted by ZTom on July 27, 2014 at 2:50 PM
  This message has been viewed 319 times.
In Reply To ZTOM I am testing my AC issues as well.. posted by Carlos Ramirez on July 26, 2014 at 08:55 PM
Message Is body harness. With the key on you should have voltage to the orange wire. If you do connect it back to the engine harness then check pin 9 and you should have voltage. if you ground that wire you will here the compressor click. Also you should have voltage on pin 19 radiator fan, ground that wire and the fan will come on. So now that everything work, the only problem would be the ECU is not providing ground.
