TwinTurbo.NET: Nissan 300ZX forum - It is. :-)
Subject It is. :-)
Posted by ZUL8R on July 24, 2014 at 9:26 AM
  This message has been viewed 122 times.
In Reply To Is that really your dad? posted by -Grimm- on July 23, 2014 at 06:47 PM
Message Not sure if he knew that was my handle when he replied to me.
Yep, it was all over the inside of drivers side wheel. I thought it might be from bubbling out of the overflow tank when it overheated and the forward motion of the car splashing it back and on the wheel.
I did bring it up to operating temp and couldn't find a leak when I had it running, but then had a puddle on the ground the next morning more or less right under the water pump.
Where I definitely screwed up is skipping the coolant pressure test. I got the kit from O'Reilly but none of the adaptors fit the radiator fill hole. Any ideas on how I should have addressed that?
I have tried to visually inspect that coolant line that runs along the firewall (heater?), and it seems ok, but I can't get a great look at it.
"Yeah, it can break the tires loose."
