TwinTurbo.NET: Nissan 300ZX forum - Ash's lifter rebuild guide:
ttsmokin
on July 22, 2014 at 6:44 PM
Now this opens up another discussion...
posted by -Grimm-
on July 22, 2014 at 04:22 PM
Fires on 3 cyls. The maf determines what side
jem_usmc
17:33:39 07/21/14
How did you determine the maf was bad?
ttsmokin
22:27:05 07/21/14
Re: How did you determine the maf was bad?
jem_usmc
04:52:10 07/22/14
Did you bleed the lifters after you put them back together?
ttsmokin
14:23:30 07/22/14
-Grimm-
16:22:01 07/22/14
Re: Now this opens up another discussion...
jem_usmc
16:33:12 07/22/14
Ash's lifter rebuild guide: -
ttsmokin
18:44:25 07/22/14
Re: Did you bleed the lifters after you put them back together?
jem_usmc
16:28:12 07/22/14
Re: Re: Did you bleed the lifters after you put them back together?
jem_usmc
16:46:22 07/22/14
Re: Re: Re: Did you bleed the lifters after you put them back together?
jem_usmc
16:59:46 07/22/14
When you installed the injectors...
ttsmokin
18:54:13 07/22/14
Re: When you installed the injectors...
jem_usmc
20:25:00 07/22/14
I would imagine WD-40 is not the best for that
ttsmokin
21:14:09 07/22/14
Re: I would imagine WD-40 is not the best for that
jem_usmc
20:38:11 07/23/14
